Bug 1448 - Some problems with series
Summary: Some problems with series
Status: RESOLVED INVALID
Reported: 2016-02-25 19:58 EST by Shinobu Nagai
Modified: 2016-03-08 06:25 EST (History)
Description Shinobu Nagai 2016-02-25 19:58:25 EST
Please follow the steps below using TeeChart for .NET v4.1.2015.12160:
Issue1. Map series:
1. Creates a new project and places a TChart compornent on a form.
2. Opens Chart Editor and adds a Map series either from the Extended or Map tab.
3. Deletes the added Map series by clicking the Delete button.
It's deleted from Chart Editor, but remains in the component tray. If I try to delete it from the component tray, I keep getting an error endlessly that says...
Type 'System.ComponentModel.Component' of assembly 'System, Version=xxxx, Culture=newtral, PublickKeyToken=xxxxxxxxxxxxxxxx' isn't set as serializable.
Issue2. Renko series:
2. Opens Chart Editor and adds a Renko series from the Financial tab.
A Volume series is automatically added together with a Renko series. Is it correct?
Thank you in advance,
Comment 1 Shinobu Nagai 2016-02-25 20:22:16 EST
There are some other problems with series.
Issue3. ColorGrid series:
* This only occurs when the language is set to Japanese. It doesn't occur with English.
2. Opens Chart Editor and adds a ColorGrid series from the 3D tab.
At this point, the ColorGrid series is displayed in the default series color (blue).
3. If navigating to other tabs, it changes to palette color.
4. If changing the color to Range and going to the Series tab, it's back to Palette.
Issue4. IsoSurface seris:
2. Opens Chart Editor and adds a IsoSurface series from the 3D tab.
It's only displayed at the top of the chart.
Comment 2 Shinobu Nagai 2016-02-25 20:56:01 EST
There is another issue.
Issue5. Ternary series:
2. Opens Chart Editor, adds a Ternary series from the Stats tab and then goes to the Themes tab.
Chart Editor is automatically closed. Just before closed, a red X mark is displayed at the preview section in Chart Editor.
Comment 3 christopher ireland 2016-03-08 06:25:38 EST
Please add only one issue to each ticket. These four issues are now in four separate tickets:
http://bugs.teechart.net/show_bug.cgi?id=1461
http://bugs.teechart.net/show_bug.cgi?id=1462
http://bugs.teechart.net/show_bug.cgi?id=1463
http://bugs.teechart.net/show_bug.cgi?id=1464
this ticket will now be closed. Thank you in advance for your cooperation.
