Bug 1446 - The editor doesn't re-adjust its size when the text size of computer is changed.
Summary: The editor doesn't re-adjust its size when the text size of computer is changed.
Reported: 2016-02-24 10:23 EST by sandra pazos
Modified: 2017-03-07 02:18 EST (History)
Description sandra pazos 2016-02-24 10:23:05 EST
The editor doesn't re-adjust its size when the text size of computer is changed. To reproduce the problem, you should only change the Text size of computer(125%-140%) in Control Panel\Appearance and Personalitzation\Display
Comment 1 yeray alonso 2017-02-21 03:51:51 EST
Reproduced with Windows 7.
Works fine in Windows 10.
Comment 2 yeray alonso 2017-03-01 02:47:56 EST
It's reproducible in Windows 10 if you logout and login again to apply the settings at system level. Before login out the changes are applied in virtualization mode (stretching everything, giving blurred texts but at correct positions).
