Bug 1427 - Legend shows the wrong colours when there are more items than can show
Summary: Legend shows the wrong colours when there are more items than can show
Reported: 2016-01-29 22:51 EST by slrworksv
Modified: 2018-02-28 10:37 EST (History)
pictures showing wrong colours on legend when not all items fit in display. (143.73 KB, image/png)
2016-01-29 22:51 EST, slrworksv
Description slrworksv 2016-01-29 22:51:57 EST
Created attachment 546 [details]
Build 3.2014.1127
I have attached 2 pictures.
The graph shows up to 30 items  (29 individual items + 1 'everything else').
When there is not enough room in the legend to show all the items (when they have long text names for instance), they get cut off.  Scroll bar would be nice here, but I understand that is coming.  BUT the reason for filing this bug, is that the legend actually changes the colours of the series in the legend so they don't match the graph.
We show largest first, so we have legend inverted true.
See pic 1.  Note that there are only 20 items showing in the legend because the text is so large for each name.  Note that the colors of the legend items do not match the colors on the graph.  The first one, Trojan cryptoblocker, should be navy - it is navy in the graph.
Now see pic 2.  As soon as I widen the graph enough to show all the series that SHOULD show in the legend.....the legend colours change to match the graph.
We can live with the legend being cut off since they are at least seeing the 'top' X.... but having the wrong colours on the legend is not acceptable.  Is there a fix for this or a workaround you can suggest?
    Sally
Comment 1 yeray alonso 2016-03-30 03:54:20 EDT
Have you reproduced the problem with SWT or Swing?
We'd need a simple example project we can run as-is to reproduce the problem here.
http://sscce.org/
Comment 2 sandra pazos 2018-02-28 10:37:43 EST
We can't reproduce the problem you're experiencing using the latest Teechart Java 3.2017.0622 Swing and the code below:
public class SwingTest
    public static TChart tChart1 = new TChart();
    static  JPanel panel = new JPanel();
    static  JButton button1 = new JButton("Editor");
    static Points series1;
    static Area s;
 public static void initializeChart()
    Random rnd = new Random();
    DateTime t = DateTime.getNow();
    //AddColors
    Color[] colors = new Color[30];
    //AddColors Array
    colors[0] = Color.fromArgb(247,168,141);// salmon
    colors[1] = Color.BISQUE;
    colors[2] = Color.BLACK;
    colors[3] = Color.BLUE;
    colors[4] = Color.CYAN;
    colors[5] = Color.DARK_GRAY;
    colors[6] = Color.FUCHSIA;
    colors[7] = Color.GOLD;
    colors[8] = Color.GRAY;
    colors[9] = Color.GREEN;
    colors[10] = Color.GREEN_YELLOW;
    colors[11] = Color.INDIGO;
    colors[12] = Color.fromArgb(4,92,89);//Dark-blue
    colors[13] = Color.LIGHT_YELLOW;
    colors[14] = Color.fromArgb(11,92,4);//Dark green
    colors[15] = Color.fromArgb(175,141,247);//Dark Purple
    colors[16] = Color.MAROON;
    colors[17] = Color.NAVY;
    colors[18] = Color.OLIVE;
    colors[19] = Color.fromArgb(141,247,210);// green
    colors[20] = Color.PINK;
    colors[21] = Color.PURPLE;
    colors[22] = Color.RED;
    colors[23] = Color.SILVER;
    colors[24] = Color.SKY_BLUE;
    colors[25] = Color.TEAL;
    colors[26] = Color.WHITE;
    colors[27] = Color.WHITE_SMOKE;
    colors[28] = Color.YELLOW;
    colors[29] = Color.fromArgb(247,210,141);//Orange-Dark
//-------------------Application-------------------------------
    panel.setBackground(Color.WHITE);
    tChart1.setBackColor(Color.WHITE);
    tChart1.getWalls().setVisible(false);
    for (int i=0; i<10; i++)
        s =new Area (tChart1.getChart());
        s.getLinePen().setVisible(false);
        s.getAreaLinesPen().setVisible(false);
        for (int x=0; x<25; x++)
            s.add(x,rnd.nextDouble());
        s.setColor(colors[i]);
        s.setMultiArea(MultiAreas.STACKED);
        s.setTitle(s.titleOrName()+"_"+"abcdefghijklmnopqrstuvwxz");
    tChart1.getLegend().setVisible(true);
    tChart1.getLegend().setAlignment(LegendAlignment.BOTTOM);
    tChart1.getLegend().getShadow().setVisible(false);
    tChart1.getLegend().setMaxNumRows(2);
     public static void main(String[] args)
     //   super.SwingTest();
        // TODO code application logic here
         java.awt.EventQueue.invokeLater(new Runnable() {
            @Override
            public void run()
             initializeChart();
             JFrame f = new JFrame();
             f.setDefaultCloseOperation(JFrame.EXIT_ON_CLOSE);
             f.getContentPane().add(tChart1);
        //     panel.setSize(800, 650);
          //   tChart1.setSize(800,650);
             f.setSize(650, 450);
            // f.setLocation(200,200);
             f.setVisible(true);
