Bug 1426 - Bottom Axis labels area is scaled with chart size and labels can get clipped
Summary: Bottom Axis labels area is scaled with chart size and labels can get clipped
Version: 3.2015.0108
Reported: 2016-01-29 15:11 EST by Jay Rinkel
Modified: 2016-02-17 06:17 EST (History)
source code to demonstrate problem (1.48 KB, text/plain)
2016-01-29 15:11 EST, Jay Rinkel
Description Jay Rinkel 2016-01-29 15:11:52 EST
Created attachment 545 [details]
The bottom axis label size gets scaled along with the size of the chart on the screen. If the chart size is small enough, then the labels actually become clipped and cannot be seen. This problem is not present in the 2013 version of TeeChart. Attempts to manually set the label size programmatically in the recent 2015 version of TeeChart has no effect (in the 2013 version of TeeChart, manual label size setting does work).
Comment 1 yeray alonso 2016-02-17 06:17:33 EST
Axis labels had a significant modification the 15th April 2015 and this problem isn't reproducible from there.
So the next maintenance release should fix this problem.
