Bug 1390 - Strange axis labels for small values
Summary: Strange axis labels for small values
Version: 150901
: High normal
Reported: 2015-12-10 07:13 EST by yeray alonso
Modified: 2016-01-22 10:17 EST (History)
test project and screenshots (221.98 KB, application/zip)
2015-12-10 07:13 EST, yeray alonso
test different ranges of values and different teechart versions (114.46 KB, application/octet-stream)
2016-01-22 10:16 EST, yeray alonso
Description yeray alonso 2015-12-10 07:13:11 EST
Created attachment 533 [details]
Depending on the series values and the chart height we can get:
#1 One label with a very higher exponent than the used for the rest of labels
#2 Only one label is drawn
#3 Only three labels are drawn on the top
See the project and the screenshots attached
Comment 1 yeray alonso 2016-01-22 10:16:32 EST
Created attachment 538 [details]
This is probably related or the very same problem:
http://www.teechart.net/support/viewtopic.php?f=1&t=15924
In the attached project I'm adding values on different ranges to see the difference.
The zip includes screenshots showing the evolution between the versions. Basically to see how the results changed in some cases from v2014.12 and later again from v2015.14.
