Bug 139 - [TV52012181] When try to draw a 2D bezier, there is no line in the chart. If swit...
Summary: [TV52012181] When try to draw a 2D bezier, there is no line in the chart. If ...
Reported: 2007-04-24 14:26 EDT by narcís calvet
Modified: 2013-11-20 09:59 EST (History)
Description narcís calvet 2013-11-20 09:59:49 EST
If switching to 3D, there is a 2D "border" line in the chart.
I need a correct display of a 2D bezier curve!
To demonstrate the false behaviour just take a look to the "Teechartgdiplus.exe", you can download (on 20th of april 2007) at steema site or just click this Link to Demo.
1. Extract and execute the Teechartgdiplus.exe file;
2. on coming up window click the edit button (the 7th button just right of "3D" button);
(the "Edting Chart1" window appears; Series1 is marked;)
4. press button "Change...";
5. on new "TeeChart Gallery" window press tab "Extended";
6. on panel "Extended" press "Bezier";
7. close "TeeChart Gallery" window by clicking on "OK" button;
8. close "Edting Chart1" window by clicking on "close" button;
9. now you see a 2D bezier curve, but it should be drawn as 3D; Shocked
10. click button "3D" to deactivate it and the curve vanishes; Shocked
11. click button "3D" again to reactivate the 2D curve, which should be the 3D one;
12. click radio button GDI+ and wonder about the displayed things Shocked
When you view the "Bezier" sample on the "Extended" tab panel on the "TeeChart Gallery" window, you see the same behaviour, if you toggle 3D.
Marjan said:
The problem is PolyBezierTo accesses wrong points (it does not ignore first point). I think using PolyBezier might fix this, but I haven't tried it yet. Currently the workaround is to change BezierStyle or set chart 3d percent to small value. [created:2007-04-24T13:26:02.000+01:00 reported by:narcis@steema.com reported in version:8.0 (TeeChart VCL)]
