Bug 1364 - Setting the Marks arrow length to 0 doesn't have effects for negative data values
Summary: Setting the Marks arrow length to 0 doesn't have effects for negative data va...
Reported: 2015-11-02 11:02 EST by sandra pazos
Modified: 2015-12-10 06:51 EST (History)
Description sandra pazos 2015-11-02 11:02:23 EST
Setting the Marks arrow length to 0 doesn't have effects for negative values.
The code below shows you the problem:
        private void setupchart()
            Bar3D serie = new Bar3D();
            serie.Add(1);
            serie.Add(2);
            serie.Add(-2);
            serie.Add(-3);
            serie.Add(4);
            serie.Add(5);
            serie.SideMargins = false;
            tChart1.Series.Add(serie);
            serie.Pen.Visible = false;
            //Marks
            serie.Marks.Transparent = true;
            serie.Marks.ArrowLength = 0;
            serie.Marks.Arrow.Color = Color.Red;
            serie.Marks.AutoPosition = false;
            serie.Marks.Visible = true;
Comment 1 sandra pazos 2015-11-03 06:18:01 EST
Also, the problem appears if you set true the MarksOnBar property. Basically, the negative values aren't represented correctly when Marks Location property is set to end or start.
