Bug 135 - [TV52011519] PDF Export using TeeSavePanel(TPDFExportFormat, Chart1) on a Horizont...
Summary: [TV52011519] PDF Export using TeeSavePanel(TPDFExportFormat, Chart1) on a Hor...
Reported: 2006-06-26 11:46 EDT by narcís calvet
Modified: 2015-05-13 12:06 EDT (History)
Description narcís calvet 2013-11-20 09:59:37 EST
PDF Export using TeeSavePanel(TPDFExportFormat, Chart1) on a Horizontal Line Series always shows the series OutLine and LinePen even if those properties are made Invisible. Their color always appears Black no matter what they have been set to. ChartPreviewer of the same chart does not show the OutLine and LinePen.
The same bug exists in Postscript Export.
You can use this code to reproduce the issue:
Uses TeePDFCanvas, TeePSCanvas, TeExport, Series;
var Series1: THorizLineSeries;
 Series1:=THorizLineSeries.Create(self);
 Chart1.AddSeries(Series1);
 Series1.FillSampleValues();
 Series1.LinePen.Visible:=false;
 Series1.OutLine.Visible:=false;
 TeeSavePanel(TPDFExportFormat, Chart1);
 TeeSavePanel(TEPSExportFormat, Chart1);
Added by Yeray:
Probably related to this is the discussed here:
http://www.teechart.net/support/viewtopic.php?f=1&t=9153&view=unread#unread
that suggests that changing the line pen width and color and exporting to PDF, the line color comes black.
Also notice that in TeeChartOffice available on the web (compiled in 2007), it works fine. [created:2006-06-26T10:46:56.000+01:00 reported by:narcis@steema.com reported in version:7.07 (TeeChart VCL)]
Comment 1 david berneda 2015-05-13 12:06:13 EDT
Appears fixed in latest version.
