Bug 1339 - Almost no field is copied when cloning descendants of Series
Summary: Almost no field is copied when cloning descendants of Series
Hardware: PC Linux
: --- critical
Reported: 2015-10-12 09:07 EDT by alex
Modified: 2016-04-13 09:24 EDT (History)
3 users (show)
Test case for Bar series (578 bytes, text/x-java)
2015-10-20 09:21 EDT, alex
Description alex 2015-10-12 09:07:11 EDT
When using cloneSeries it creates a new object and assigns properties from the cloned one. But assign method in subclasses of Series is either not redefined or doesn't copy a lot of fields (in Series too).
For example CustomBar has fields barSizePercent, depthPercent, offsetPercent which are configurable through settings, yet are not copied when cloning.
As a results if you customized and cloned a series almost all settings would be lost.
Comment 1 alex 2015-10-20 09:21:46 EDT
Created attachment 517 [details]
This test case shows that a clonned serie doesn't copy settings from its original.
Please note that there is a lot of such fields which aren't copied and it is not limited to the Bar class. That's why fixing only these three won't help at all but writing a test case for all cases is too much. Because it's almost every field in almost every subclass of Series.
Comment 2 sandra pazos 2015-11-16 08:06:03 EST
The simple code below reproduces the problem:
public static void initializeChart()
    Bar bar = new Bar(tChart1.getChart());
    Bar  bar1 = new Bar(tChart1.getChart());
    bar.setBarWidthPercent(100);
    bar.add(77);
    bar.add(66);
    bar.add(33);
    bar.setColor(Color.red);
    bar1 = (Bar) bar.cloneSeries();
Comment 5 marc meumann 2016-04-13 09:24:49 EDT
Extensive assign modifications made for next maintenance release
