Bug 1329 - TeeChartFeatureDemo, v2015.0.0.3
Summary: TeeChartFeatureDemo, v2015.0.0.3
Component: Examples Demo (show other bugs)
Reported: 2015-10-01 01:26 EDT by Shinobu Nagai
Modified: 2016-07-26 08:28 EDT (History)
Description Shinobu Nagai 2015-10-01 01:26:23 EDT
The following issues are checked with the latest version of TeeChart ActiveX v2015.0.0.3.
1. The "Draw Zones" checkbox in All Features->Chart Styles->Extended->Polar->Zones
All Features->Chart Styles->Extended->Polar->Zones doesn't work (nothing changes).
2-1. All Features->Chart Styles->Statistical->ColorGrid->ColorGrid RealTime
The "Reuse GridIndex" checkbox is marked by default. If marking the "Animation" checkbox, it starts animation, but it only displays the last column.
2-2. If doing the same thing in GDI mode, an error message dialog is displayed. It says ...
"Parameter is wrong." If the "Reuse GridIndex" checkbox is unmarked, it doesn't occur.
3. All Features->Tools->Series Animation->Delay:
Runtime error: '-2147418113(8000ffff)' Argument out of range
occurs.
4. All Features-> Tools->Series Animation:
occurs.
5. All Features->Components->OpenGL
In this folder, there are some samples that "OpenGL" checkbox is enabled, but even if marking/unmarking it, nothing changes.
This user says if these problems only exist in the sample code, he can wait, but he doesn't know if these problems exist in the ocx or not. So, he expects you to check all of the samples at least before releasing new versions.
Users estimate the samples before/after purchasing the product, so we think they are very important. So, it's appreciated if you could fix the reported issues before releaseing new version.
Thank you in advance,
Kindest Regards,
Comment 1 Shinobu Nagai 2015-10-01 01:29:53 EDT
Hello again,
There is one more issue.
All Features->Chart Styles->DataBase Charts->Single Record
or
All Features->Chart Styles->DataBase Charts->Single Record By Code
is selected, an error occurs. It says "Type doesn't match."
Kindest Regards,
Comment 2 sandra pazos 2015-10-01 07:01:09 EDT
Hello Nagai,
1.This bug is the same as bug id850. Here's the link: http://bugs.teechart.net/show_bug.cgi?id=850
2-1. This is a new bug.
2-This bug is the same as bug id1214. Here's the link:
http://bugs.teechart.net/show_bug.cgi?id=1214
4. This is a new bug
5. This is a new bug
>>>Users estimate the samples before/after purchasing the product, so we >>>think they are very important. So, it's appreciated if you could fix the >>>reported issues before releaseing new version.
We will try to fix the problems for future maintenance releases.
>>>Or All Features->Chart Styles->DataBase Charts->Single Record By Code is >>>selected, an error occurs. It says "Type doesn't match."
The both are new bugs.
On the other hand, I would suggest you create a different bug ticket for each error you add in Bugzilla tracker instead of add all the Demo problems an only bug ticket, so, we can do a good bugs tracking.
Thanks in advance,
regards.
Comment 3 Shinobu Nagai 2016-07-22 00:33:18 EDT
We got a reply from this user, and he needs to know if these are fixed or not.
Since the last reply, they aren't fixed yet. How can we answer him?
Comment 4 sandra pazos 2016-07-26 08:28:08 EDT
Hello Nagai,
I have answered you in the thread below:
http://teechart.net/directline/viewtopic.php?f=4&t=1011&start=50#p5453
Thanks in advance
