Bug 1294 - ArrayIndexOutOfBoundsException in Pie chart
Summary: ArrayIndexOutOfBoundsException in Pie chart
: Highest blocker
Reported: 2015-09-08 11:30 EDT by alex
Modified: 2015-11-16 08:20 EST (History)
Chart Series: Pie
Description alex 2015-09-08 11:30:26 EDT
Please create Pie series. Go to Data source and create 8 random values. After that go to Format->Group Slices. Set value for example 11 and try to select style combobox to Below Percent. The chart will be broken and you will see followings log:
Exception in thread "AWT-EventQueue-0" java.lang.ArrayIndexOutOfBoundsException: 8
	at com.steema.teechart.styles.Pie.draw(Pie.java:1090)
	at com.steema.teechart.styles.Series.drawSeries(Series.java:2363)
	at com.steema.teechart.Chart.drawAllSeries(Chart.java:840)
	at com.steema.teechart.Chart.drawAxesSeries(Chart.java:802)
	at com.steema.teechart.Chart.internalDraw(Chart.java:782)
	at com.steema.teechart.Chart.paint(Chart.java:2169)
	at com.steema.teechart.TChart.paintComponent(TChart.java:645)
	at javax.swing.JComponent.paint(JComponent.java:1056)
	at javax.swing.JComponent.paintToOffscreen(JComponent.java:5219)
	at javax.swing.RepaintManager$PaintManager.paintDoubleBuffered(RepaintManager.java:1572)
	at javax.swing.RepaintManager$PaintManager.paint(RepaintManager.java:1495)
	at javax.swing.RepaintManager.paint(RepaintManager.java:1265)
	at javax.swing.JComponent._paintImmediately(JComponent.java:5167)
	at javax.swing.JComponent.paintImmediately(JComponent.java:4978)
	at javax.swing.RepaintManager$4.run(RepaintManager.java:824)
	at javax.swing.RepaintManager$4.run(RepaintManager.java:807)
	at java.security.AccessController.doPrivileged(Native Method)
	at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:75)
	at javax.swing.RepaintManager.paintDirtyRegions(RepaintManager.java:807)
	at javax.swing.RepaintManager.paintDirtyRegions(RepaintManager.java:782)
	at javax.swing.RepaintManager.prePaintDirtyRegions(RepaintManager.java:731)
	at javax.swing.RepaintManager.access$1300(RepaintManager.java:64)
	at javax.swing.RepaintManager$ProcessingRunnable.run(RepaintManager.java:1720)
	at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:311)
	at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:749)
	at java.awt.EventQueue.access$500(EventQueue.java:97)
	at java.awt.EventQueue$3.run(EventQueue.java:702)
	at java.awt.EventQueue$3.run(EventQueue.java:696)
	at java.awt.EventQueue.dispatchEvent(EventQueue.java:719)
	at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:201)
	at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116)
	at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:109)
	at java.awt.WaitDispatchSupport$2.run(WaitDispatchSupport.java:184)
	at java.awt.WaitDispatchSupport$4.run(WaitDispatchSupport.java:229)
	at java.awt.WaitDispatchSupport$4.run(WaitDispatchSupport.java:227)
	at java.awt.WaitDispatchSupport.enter(WaitDispatchSupport.java:227)
	at java.awt.Dialog.show(Dialog.java:1084)
	at java.awt.Component.show(Component.java:1654)
	at java.awt.Component.setVisible(Component.java:1606)
	at java.awt.Window.setVisible(Window.java:1014)
	at java.awt.Dialog.setVisible(Dialog.java:1005)
	at com.steema.teechart.editors.ChartEditor.editChart(ChartEditor.java:107)
	at com.steema.teechart.editors.ChartEditor.editChart(ChartEditor.java:102)
	at com.steema.teechart.Commander$1.actionPerformed(Commander.java:116)
	at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2022)
	at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2346)
	at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:402)
	at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:259)
	at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:252)
