Bug 1291 - TChartSeriesList method MaxYValue doesn't return any Y value with TIsoSurfaceSerie
Summary: TChartSeriesList method MaxYValue doesn't return any Y value with TIsoSurface...
Version: 150120
Reported: 2015-09-04 07:45 EDT by Johan DEVELON
Modified: 2015-10-21 06:41 EDT (History)
Chart Series: IsoSurface
Delphi / C++ Builder RAD IDE Version: RAD XE7
Description Johan DEVELON 2015-09-04 07:45:41 EDT
If you use a TChartSeriesList, the method to get the MaxYvalue from a IsoSurfaceSerie return at each time the MaxZValue and not the Y as demanded.
//Example for testing
var
MyList:TChartSeriesList;
MySeries:TIsoSurfaceSeries;
ValX,ValZ:integer;
MyList:=TChartSeriesList.Create;
ValX:=5;
MySeries:= TIsoSurfaceSeries.Create(self);
for ValZ:=0 to 10 do MySeries.AddXYZ(ValX,ValX*ValZ,ValZ);
MyList.Add(MySeries);
showmessage(
'X='+floattostr(MyList[0].MaxXValue)+chr(13)
'Y='+floattostr(MyList[0].MaxYValue)+chr(13)
'Z='+floattostr(MyList[0].MaxZValue)
MySeries.Free;
MyList.Free;
Not tested with other 3D series.
used with delphi XE7 -32bits
Comment 1 sandra pazos 2015-10-21 06:41:33 EDT
Hello Johan,
Sorry for the delay. I would like inform you that the problem you are experiencis isn’t a bug. The property MaxYValue works only when the 3D Series is added in Chart.  To fix the problem, you should use the YValues Directly instead of MaxYValues. The code below shows you how:
showmessage('X='+floattostr(Series1.XValues.MaxValue)+chr(13)+'Y='+floattostr(Series1.YValues.MaxValue)+chr(13)+'Z='+floattostr(Series1.ZValues.MaxValue));
Thanks in advance
Regards
