Bug 1285 - Histogram sort Y does not work after source value changing
Summary: Histogram sort Y does not work after source value changing
Component: Functions (show other bugs)
Version: 150420
Reported: 2015-08-31 04:01 EDT by Bert Kreisel
Modified: 2015-08-31 08:11 EDT (History)
Chart Series: Line
Description Bert Kreisel 2015-08-31 04:01:43 EDT
Let a Histogram funktion series be sorted by "Y".
After Changing the values of the source series (change the number of sample values of a random serie) the Histogram series is no longer sorted by "Y". (It will be sorted again after changing the sort settings.)
Comment 1 sandra pazos 2015-08-31 08:11:25 EDT
Hello Bert,
Thanks for your requests. We can reproduce it. Seems the problem is caused, because, is necessary use the CheckOrder method in design-time. We will try to fix it to upcoming version of TeeChart Pro VCL/FMX.  Meantime, you can use the code below in runtime to fix the problem:
type
  TForm1 = class(TForm)
    Chart1: TChart;
    Series1: TBarSeries;
    Series2: TFastLineSeries;
    TeeFunction1: THistogramFunction;
    TeeCommander1: TTeeCommander;
  private
    { Private declarations }
  public
    { Public declarations }
var
  Form1: TForm1;
implementation
{$R *.dfm}
Series1.FillSampleValues(10);
Series2.YValues.Order := loAscending;
Series2.CheckOrder;
