Bug 1232 - Histogram series with a single values makes wrong axis range.
Summary: Histogram series with a single values makes wrong axis range.
Reported: 2015-06-10 05:26 EDT by narcís calvet
Modified: 2015-07-29 09:33 EDT (History)
Description narcís calvet 2015-06-10 05:26:15 EDT
In the code snippet below, adding one single value to the second Histogram series completely breaks bottom axis scale.
      Steema.TeeChart.Styles.Histogram histogram1 = new Steema.TeeChart.Styles.Histogram(tChart1.Chart);
      Steema.TeeChart.Styles.Histogram histogram2 = new Steema.TeeChart.Styles.Histogram(tChart1.Chart);
      for (int i = 0; i < 24; i++)
        histogram1.Add(i);
      double tmp = histogram1.MaxYValue() + 1;
      histogram1.Add(tmp);
      histogram2.Add(tmp);
Comment 1 narcís calvet 2015-06-10 05:46:16 EDT
Something similar occurs when adding a 2nd point to the 2nd series:
        histogram1.Add(i);
Comment 2 narcís calvet 2015-06-10 05:52:01 EDT
A workaround to the problem is adding a negative MinimumOffset value to the bottom axis:
tChart1.Axes.Bottom.MinimumOffset = -1;
Comment 3 christopher ireland 2015-06-10 06:14:46 EDT
Similar problem in VCL:
http://bugs.teechart.net/show_bug.cgi?id=1233
Comment 4 christopher ireland 2015-07-29 09:32:59 EDT
This issue can be fixed by the addition of null points, e.g.
        histogram1.Add(i);
        histogram2.Add();
