Bug 1215 - Improve ColorGrid performance
Summary: Improve ColorGrid performance
Reported: 2015-05-20 05:38 EDT by christopher ireland
Modified: 2015-05-20 05:38 EDT (History)
Description christopher ireland 2015-05-20 05:38:36 EDT
The following code takes over six seconds to draw; improvements to this performance are required:
		private Stopwatch watch = new Stopwatch();
		private ColorGrid _colorGrid;
		private LegendPalette _legendPalette;
		private Color[] _rainbowLowBlackPalette;
		private double _colorBarMax;
		private double _colorBarMin;
		private double _colorBarStep;
		private double[] _xData;
		private double[] _yData;
		private double[] _zData;
			_colorBarMax = 0.0;
			_colorBarMin = -50.0;
			_colorBarStep = 5.0;
			watch.Reset();
			watch.Start();
			SetupColorGrid();
			GenerateData();
			_colorGrid.Add(_xData, _zData, _yData);
      _colorGrid.IrregularGrid = true;
			_legendPalette.Series = _colorGrid;
			_legendPalette.Gradient.Visible = false;
		private void TChart1_AfterDraw(object sender, Graphics3D g)
			watch.Stop();
			label1.Text = watch.ElapsedMilliseconds.ToString();
		public void SetupColorGrid()
			this.SuspendLayout();
			this.tChart1.Aspect.SmoothingMode = System.Drawing.Drawing2D.SmoothingMode.Default;
			this.tChart1.Aspect.TextRenderingHint = System.Drawing.Text.TextRenderingHint.SystemDefault;
			this.tChart1.Aspect.View3D = false;
			tChart1.Header.Visible = false;
			tChart1.Panel.MarginUnits = Steema.TeeChart.PanelMarginUnits.Pixels;
			tChart1.Panel.MarginRight = 80;
			tChart1.Axes.Bottom.Automatic = false;
			tChart1.Axes.Bottom.AutomaticMaximum = false;
			tChart1.Axes.Bottom.AutomaticMinimum = false;
			tChart1.Axes.Bottom.Increment = 0.2;
			tChart1.Axes.Bottom.Maximum = 1.0;
			tChart1.Axes.Bottom.Minimum = -1.0;
			tChart1.Axes.Left.Automatic = false;
			tChart1.Axes.Left.AutomaticMaximum = false;
			tChart1.Axes.Left.AutomaticMinimum = false;
			tChart1.Axes.Left.Increment = 0.2;
			tChart1.Axes.Left.Maximum = 1.0;
			tChart1.Axes.Left.Minimum = -1.0;
			this._colorGrid = new ColorGrid();
			this._colorGrid.Pen.Visible = false;
			this._colorGrid.Title = "colorGrid1";
			this._colorGrid.UseColorRange = false;
			this._colorGrid.UsePalette = true;
			this._colorGrid.XStep = 1;
			this.tChart1.Series.Add(this._colorGrid);
			LoadColorPalette();
			_legendPalette = new LegendPalette(tChart1.Chart);
			_legendPalette.Axis = LegendPaletteAxis.laOther;
			_legendPalette.Width = 60;
			_legendPalette.Pen.Visible = false;
			this.ResumeLayout(false);
			tChart1.SizeChanged += new System.EventHandler(this.Chart_SizeChanged);
		private void Chart_SizeChanged(object sender, EventArgs e)
			watch.Reset();
			watch.Start();
			tChart1.AutoRepaint = false;
			_legendPalette.Left = tChart1.Width - _legendPalette.Width - 10;
			_legendPalette.Top = (tChart1.Height - _legendPalette.Height) / 2;
			tChart1.AutoRepaint = true;
			tChart1.Refresh();
		private void LoadColorPalette()
			double minValue = _colorBarMin;
			double maxValue = _colorBarMax;
			double delta = _colorBarMax - _colorBarMin;
			_colorGrid.ClearPalette();
			_rainbowLowBlackPalette = new Color[256];
			int redIndex;
			int greenIndex;
			int blueIndex;
			for (int i = 0; i < 256; i++)
				if (i == 0)
					redIndex = 0;
					greenIndex = 0;
					blueIndex = 0;
				else if (i > 0 && i <= 32)
					redIndex = -255 / 32 * i + 255;
					greenIndex = 0;
					blueIndex = 255;
				else if (i > 32 && i <= 85)
					redIndex = 0;
					greenIndex = (255 / (85 - 32)) * (i - 32);
					blueIndex = 255;
				else if (i > 85 && i <= 143)
					redIndex = 0;
					greenIndex = 255;
					blueIndex = (-255 / (143 - 86)) * (i - 143);
				else if (i > 143 && i <= 199)
					redIndex = (255 / (199 - 143)) * (i - 143);
					greenIndex = 255;
					blueIndex = 0;
					redIndex = 255;
					greenIndex = (-255 / (255 - 199)) * (i - 255);
					blueIndex = 0;
				_rainbowLowBlackPalette[i] = Color.FromArgb(redIndex, greenIndex, blueIndex);
				_colorGrid.AddPalette(((delta / 255.0) * (double)i + minValue), _rainbowLowBlackPalette[i]);
		private void GenerateData()
			var Nx = 50;
			var Ny = 25;
			var Nu = 1001;
			var Nv = 1001;
			_xData = new double[Nu * Nv];
			_yData = new double[Nu * Nv];
			_zData = new double[Nu * Nv];
			var du = 2.0 / (Nu - 1);
			var dv = 2.0 / (Nv - 1);
			int k = 0;
			for (int i = 0; i < Nu; i++)
				var v = -1.0 + dv * i;
				for (int j = 0; j < Nv; j++)
					var u = -1.0 + du * j;
					var argx = 0.5 * Nx * u;
					var argy = 0.5 * Ny * v;
					_xData[k] = u;
					_yData[k] = v;
					_zData[k] = 20.0 * Math.Log10(Math.Abs(sinc(argx) * sinc(argy)));
					k++;
		private double sinc(double x)
			if (Math.Abs(x) < 1.0e-7)
				return 1.0;
				return (Math.Sin(Math.PI * x) / (Math.PI * x));
