Bug 120 - [TV52013073] I have a problem with a 2D filled Contour plots. Just placing a ch...
Summary: [TV52013073] I have a problem with a 2D filled Contour plots. Just placing a ...
Reported: 2008-05-27 14:59 EDT by narcís calvet
Modified: 2013-12-19 10:14 EST (History)
Random Contour series filled correctly (36.32 KB, image/png)
2013-12-19 10:13 EST, david berneda
Description narcís calvet 2013-11-20 09:58:46 EST
Just placing a chart with a 2D contour series and using the code below:
var i, j: Integer;
 Series1.IrregularGrid:=true;
 Series1.Brush.Style:=bsSolid;
 for i:=0 to 9 do
 for j:=0 to 24 do
 Series1.AddXYZ(i, i*j-random(Round(0.5*i*j)),j);
This gives contours which are not filled correctly (e.g. filled area outside contour lines and areas with white triangles). If I just use AddXYZ (i,i*j,j); the contour is drawn perfectly.
My guess is that internal IsoSurface series used for filling the contour levels doesn't take into account intermediate level points in a cell, it just uses cell intersections with levels.
Same happens with .NET version: TF02014290. [created:2008-05-27T13:59:34.000+01:00 reported by:narcis@steema.com reported in version:8.01 (TeeChart VCL)]
Comment 1 david berneda 2013-12-19 10:13:50 EST
Created attachment 61 [details]
Comment 2 david berneda 2013-12-19 10:14:21 EST
Contour filling now resolves polygons using the same coordinates as contour level lines segments.
