Bug 1184 - StackOverflowException in Styles.Points series
Summary: StackOverflowException in Styles.Points series
: --- critical
Reported: 2015-04-01 05:43 EDT by sdgr
Modified: 2015-05-12 05:57 EDT (History)
Chart Series: PointXY
Description sdgr 2015-04-01 05:43:35 EDT
Simply create a new windows project in VS2013 and add a TeeChart component and  one simple button.
Add one series to the Chart:
    private Steema.TeeChart.Styles.Points points1;
Add code behind the button:
      points1.Add(0, 5);
      points1.Add(1, 1.79E+308);
Run the application and press the button, you will get a StackOverflowException.
Is there a workaround? Thanks.
Stefan.
Comment 1 christopher ireland 2015-04-01 07:13:03 EDT
Hello Stefan,
This error is being produced in the TeeChart code here:
        if (IAxisSize > 0)
          tmp = inverted ? IEndPos - value : value - IStartPos;
          tmp *= iRange / IAxisSize;
          return horizontal ? iMinimum + tmp : iMaximum - tmp;
tmp is calculated as Double.Infinity. In fact, the same issue can be observed running the following code:
      double large = 1.79E+308;
      large *= 500;
500 is about the normal size of the value of tmp, with iRange having a slightly larger value than 1.79E+308. I will have to think a little about the best way of avoiding this error being thrown. Many thanks for reporting it to us.
Comment 2 christopher ireland 2015-04-02 06:02:47 EDT
Stefan,
The best workaround I've found to date would be this:
      Points points1 = new Points(tChart1.Chart);
      points1.Pointer.InflateMargins = false;
      points1.ValueFormat = "0.###E+0";
      tChart1.Axes.Left.Labels.ValueFormat = "0.###E+0";
      tChart1.GetNextAxisLabel +=tChart1_GetNextAxisLabel;
      points1.Add(0, 5);
    void tChart1_GetNextAxisLabel(object sender, GetNextAxisLabelEventArgs e)
      if (((Steema.TeeChart.Axis)sender).Equals(tChart1.Axes.Left))
        e.Stop = false;
        switch (e.LabelIndex)
          case 0:
            e.LabelValue = 5;
            break;
          case 1:
            e.LabelValue = 1.79E+308;
            break;
          default:
            e.Stop = true;
            break;
It is always different working with values whose arithmetic relationship is beyond double precision, such as (5, 1.79E+308) ... e.g.
      double small = 5;
      double subtract = large - small;
      MessageBox.Show(Utils.MinimalDifference(large, subtract, 1).ToString());
