Bug 1173 - axis title with angle=90 of custom vertical axis -> position horizontal position depends of Title Caption
Summary: axis title with angle=90 of custom vertical axis -> position horizontal posit...
Version: 150120
Reported: 2015-03-16 03:32 EDT by Bert Kreisel
Modified: 2015-04-17 07:30 EDT (History)
3 users (show)
Description Bert Kreisel 2015-03-16 03:32:06 EDT
The horizontal position of the axis title with Angle=90 of a custom vertical axis changed with the length of the Title.Caption. Longer titles becomes more space to the axis. Normal length title (10 char) are no longer in the visible range of our charts!
Comment 1 narcís calvet 2015-04-01 09:33:59 EDT
This can be reproduced with the code snippet below.
uses Series;
Var MyAxis : TChartAxis ;
  Chart1.AddSeries(TLineSeries.Create(Self)).FillSampleValues;
  MyAxis:=TChartAxis.Create(Chart1);
  MyAxis.Title.Caption:='Extra axis';
  MyAxis.Title.Angle:=90;
  Chart1[0].CustomVertAxis:=MyAxis;
Comment 2 narcís calvet 2015-04-01 10:15:48 EDT
At TeEngine.pas, implementing TChartAxis.GetAxisTitle as shown below solves the problem.
function TChartAxis.GetAxisTitle:TChartAxisTitle;
  if not Assigned(FAxisTitle) then
    FAxisTitle:=TChartAxisTitle.Create(ParentChart);
    if not Self.Horizontal then
      if (Self=ParentChart.FLeftAxis) or not Self.OtherSide then
         FAxisTitle.InitAngle(90)
      if (Self=ParentChart.FRightAxis) or Self.OtherSide then
         FAxisTitle.InitAngle(270);
    FAxisTitle.IDefaultAngle:=FAxisTitle.Angle;
  result:=FAxisTitle;
Comment 3 Bert Kreisel 2015-04-07 03:22:03 EDT
The problem persists for (Angle=270 and not OtherSide) and
(Angle=90 and OtherSide)
Comment 4 narcís calvet 2015-04-13 06:10:59 EDT
Yes, that's right. Drop a TChart component into a form and use the code snippet below to reproduce it:
uses Series;
Var
  MyAxis1, MyAxis2 : TChartAxis;
  MyAxis1:=TChartAxis.Create(Chart1);
  MyAxis1.Title.Caption:='Extra axis';
  MyAxis1.Title.Angle:=270;
  MyAxis2:=TChartAxis.Create(Chart1);
  MyAxis2.Title.Caption:='Extra axis';
  MyAxis2.Title.Angle:=90;
  MyAxis2.OtherSide:=True;
  Chart1[0].CustomVertAxis:=MyAxis1;
  Chart1[1].HorizAxis:=aBothHorizAxis;
  Chart1[1].VertAxis:=aBothVertAxis;
  Chart1[2].CustomVertAxis:=MyAxis2;
  Chart1.Axes.Left.Title.Caption:='left axis title';
  Chart1.Axes.Bottom.Title.Caption:='bottom axis title';
  Chart1.Axes.Right.Title.Caption:='right axis title';
  Chart1.Axes.Top.Title.Caption:='top axis title';
Comment 5 johannes.barthelmaes 2015-04-17 07:19:26 EDT
Hey Narcis,
what about the problem described by Bert?
Is this already fixed?
Comment 6 narcís calvet 2015-04-17 07:30:55 EDT
Hi Johannes,
Yes, it is. Please check your email.
