Bug 1160 - Having an TImageShape with VertOffset on Bottom Aligned Text, the VertScrollBar doesn't calculate limits correctly
Summary: Having an TImageShape with VertOffset on Bottom Aligned Text, the VertScrollB...
Component: TTree (show other bugs)
Version: 150120
URL: http://stackoverflow.com/questions/28...
Reported: 2015-03-10 07:18 EDT by yeray alonso
Modified: 2015-05-15 05:38 EDT (History)
Description yeray alonso 2015-03-10 07:18:25 EDT
If you place a TTree and use this code (note the Tree has to be small enough to show the Vertical ScrollBar):
var i:Integer;
    imgBox:TImageShape;
    curLeft,curTop:Integer;
  curLeft:=-100-15;
  curTop:=0;
  for i:=0 to 10 do
    imgBox := TImageShape.Create(Self);
    imgBox.Width := 100;
    imgBox.Height := 100;
    curLeft := curLeft + 100 + 15 * 2;
    if (curLeft + 100 + 15)>= Tree1.Width then
      curLeft := 15;
      curTop := curTop + 100 + 15 * 2;
    imgBox.Left := curLeft;
    imgBox.Top := curTop;
    imgBox.Font.Style:=[fsBold];
    imgBox.Font.Size:=16;
    imgBox.Text.VertAlign:=vtaBottom;
    imgBox.Text.VertOffset:=30;
    imgBox.Text.Add('Node'+inttostr(i));
    imgBox.Tree:=Tree1;
If you use the ScrollBar to show the shapes on the bottom, the scrollbar doesn't allow you to scroll enough to see all the texts.
Possible fix:
At TeeTree.pas, in the TTreeNodeShape.ReCalcPositions method there is:
  FAdjustedRect.Left:=X0;
  FAdjustedRect.Top:=Y0;
  FAdjustedRect.Right:=FX1;
  FAdjustedRect.Bottom:=FY1;
If you change it for this, the texts will be shown:
  FAdjustedRect.Right:=FX1+FText.HorizOffset;
  FAdjustedRect.Bottom:=FY1+FText.VertOffset;
Comment 1 david berneda 2015-05-15 05:38:59 EDT
A minor improvement to this test is to set the text selected color to black, otherwise selecting nodes will paint text in white color and will be invisible:
  Tree1.Selected.TextColor:=clBlack;
