Bug 1157 - Caching impeding designtime changes when modifying gardient direction in Bar fill gradients
Summary: Caching impeding designtime changes when modifying gardient direction in Bar ...
Reported: 2015-03-03 05:51 EST by marc meumann
Modified: 2015-03-03 09:56 EST (History)
Description marc meumann 2015-03-03 05:51:13 EST
Making changes to a Barseries' fill gradient (eg. Direction) isn't showing up at designtime when making those changes with the editor.
Workaround:
Disabling cache resolves the issue.
ie. Steema.TeeChart.Utils.UseCaches = false;
Comment 1 christopher ireland 2015-03-03 09:31:46 EST
The following code works as expected with UseCaches either true or false:
    Bar series = new Bar();
      tChart1.Series.Add(series);
      series.FillSampleValues();
      series.Gradient.Visible = true;
      //Utils.UseCaches = false;
      EditorUtils.FillEnum(comboBox1, typeof(LinearGradientMode));
    private void comboBox1_SelectedIndexChanged(object sender, EventArgs e)
      series.Gradient.Direction = (LinearGradientMode)comboBox1.SelectedItem;
Also, using the Chart Editor at runtime means works as expected when changing the Gradient Direction. The Chart Editor at designtime seems to be the only area in which this issue occurs.
Comment 2 christopher ireland 2015-03-03 09:48:17 EST
Last comment inaccurate, code snippet can reproduce issue with Utils.Caches = true.
