Bug 1155 - TabOrder not found when exporting a TChart and Importing to a TQRChart
Summary: TabOrder not found when exporting a TChart and Importing to a TQRChart
Version: 150120
: Lowest trivial
Reported: 2015-03-02 06:59 EST by yeray alonso
Modified: 2015-05-11 09:12 EDT (History)
Description yeray alonso 2015-03-02 06:59:44 EST
A customer is trying move a TChart to a TQRChart.
If I do this I get an error saying "TabOrder not found":
var tmpStream: TMemoryStream;
  tmpStream:=TMemoryStream.Create;
  SaveChartToStream(Chart1, tmpStream);
  tmpStream.Position:=0;
  LoadChartFromStream(TCustomDBChart(QRDBChart1), tmpStream);
  QRDBChart1.Parent:=QuickRep1;
Using CloneChart works fine.
Comment 1 david berneda 2015-05-11 09:12:40 EDT
TabOrder cannot be made published in TQRChart or TQRDBChart.
For this property (and also any other properties not supported by QR controls), using LoadChartFromStreamCheck solves the problem.
function TForm1.SkipErrors(const Message: string): Boolean;
  result:=True; // <-- True means: continue reading, ignore the exception(s)
  LoadChartFromStreamCheck(TCustomDBChart(QRDBChart1), tmpStream, SkipErrors);
"SkipErrors" is a local function that returns True to avoid the exception and continue loading the chart.
Note: Running inside the IDE with debugging will still stop the application when the exception happens, pressing F9 (run) again will continue as expected.
Running "without debugging" will not stop at all.
