Bug 1154 - Printing issue using Printer.PrintPartialHandle command
Summary: Printing issue using Printer.PrintPartialHandle command
: 1163 (view as bug list)
Reported: 2015-02-27 06:51 EST by kchan
Modified: 2015-03-17 10:46 EDT (History)
zip file containing a vb6 project and a JPEG screenshot (66.02 KB, application/x-zip-compressed)
2015-02-27 06:51 EST, kchan
Description kchan 2015-02-27 06:51:56 EST
Created attachment 410 [details]
Upgrading from Teechart v6 to Teechart v2014 v2014.0.0.1
Using TChart.Printer.PrintPartialHandle command to dynamically print text and Teechart.
Find the text for Title, Axis labels, Legend, is significantly larger when printed out, than what is displayed on the screen. It prints correctly sized in Teechart v6, using the same code.
Has there been a change to Teechart v2014 I need to be aware of?
Attached is a zip file of a simple VB6 project showing the problem.
Also included is JPEG screenshot showing the print result of it with text being larger.
Language: English
OS: Windows 7 64 bit
Comment 1 sandra pazos 2015-03-03 11:42:57 EST
The problem is produced when GDI+ is enable. Meantime, if you want fix the problem you can disable the GDI+.
Comment 2 kchan 2015-03-10 07:21:06 EDT
Thank you for advising to switch off GDI+. I am attempting to do this through code using command
    TChart1.Aspect.GDIPlus.Active = False
It gave a memory exception. Then read this article
http://steema.com/wp/blog/2014/03/12/teechart-and-gdi-inside-a-dll/
So attempted to initialise a GDI+ object before setting GDIPlus to false.
    tStartup.DebugEventCallback = 0
    tStartup.SuppressBackgroundThread = False
    tStartup.SuppressExternalCodecs = False
    tStartup.GdiplusVersion = 1
    GdiplusStartup token, tStartup, 0
    GdiplusShutdown token
But unfortunately this has not worked. Can you advise on a possible solution as soon as possible?
Comment 3 sandra pazos 2015-03-13 10:45:07 EDT
*** Bug 1163 has been marked as a duplicate of this bug. ***
