Bug 1146 - samples in the TeeChart Pro v2014 ActiveX Control\Examples\Visual Studio .NET folder
Summary: samples in the TeeChart Pro v2014 ActiveX Control\Examples\Visual Studio .NET...
Component: Examples Demo (show other bugs)
Reported: 2015-02-18 21:42 EST by Shinobu Nagai
Modified: 2015-05-27 07:51 EDT (History)
Description Shinobu Nagai 2015-02-18 21:42:36 EST
Regarding the samples in the TeeChart Pro v2014 ActiveX Control\Examples\Visual Studio .NET folder, for example, is it possible to run Examples\Visual Studio .NET\CSharp\Dragging sample project at your end?
If it runs at your end, please let us know the VS version; did you run it from .sln or .proj file? It's also required to add References again. From where did you add them?
Comment 1 sandra pazos 2015-03-02 10:30:06 EST
Hello Nagai,
We have considered it as a bug. Meantime, you can fix that following the steps below:
1-Open Dragging example.
2-Remove the AxTeeChart and TeeChart from references folder
3-Add an extra form.
4-Add Teechart2014.ocx in the Tool List.
5-Add Chart in the new form.
6-Save changes and remove the new form.
Now you should be able to run the project.
Comment 2 Shinobu Nagai 2015-03-04 00:54:56 EST
Hello Sandra,
Let me make sure one thing.
The "Steema Software\TeeChart Pro v2014 ActiveX Control\Utilities\Vs.net\Strong Named DLLs" folder contains the following dlls:
・AxInterop.TeeChart.dll
・TeeChart.dll
Is it possible to use them?
Comment 3 sandra pazos 2015-03-06 11:20:50 EST
Hello Nagai,
I am afraid the Strong Named DLLs don't fix the problem. We will review the AxInterop.TeeChart.dll and TeeChart.dll, too.
Thanks in advance
Regards.
Comment 4 Shinobu Nagai 2015-04-15 22:45:54 EDT
We downloaded and installed the latest version (v2015.0.0.0), but we still get the errors, even though we followed the steps you mentioned below.
Please let us know another steps to run them without any errors?
Thank you in advance,
Comment 5 sandra pazos 2015-05-27 07:51:46 EDT
Hello Nagai,
The problem isn't fixed. We will inform you when it is solved.
Thanks in advance,
