Bug 114 - GPF in function LongPathName
Summary: GPF in function LongPathName
Version: 131016
Reported: 2013-11-19 18:07 EST by John Santmann
Modified: 2013-11-29 10:07 EST (History)
Description John Santmann 2013-11-19 18:07:34 EST
Problem with the following procedure which generates GPF because it needs GetLongPathNameW instead of GetLongPathNameA.
In addition, the buffer is one byte too small.
Fix is in code below.
function LongPathName(const FileName:String):String;
var
  BufferSize: DWord;
  // "GetLongPathNameA" available only for Win2000, WinXP or Win2003, or newer !
  if (Win32Platform=VER_PLATFORM_WIN32_NT) and (WindowsMajorVersion>=5) then
// --------- BEGIN REMOVED CODE -----------
    if TeeKernel32=0 then
      TeeKernel32:=TeeLoadLibrary(kernel32);
      if TeeKernel32<>0 then
         @GetLongPathName:=GetProcAddress(TeeKernel32,'GetLongPathNameA');
    BufferSize := GetLongPathName(PChar(FileName), nil, 0);
    SetLength(Result, BufferSize - 1);
    GetLongPathName(PChar(FileName), PChar(Result), BufferSize);
// ----------- END RREMOVED CODE ----------
    // 2/19/2009 ------------ BEGIN CODE ADDED -----------------
         @GetLongPathName:=GetProcAddress(TeeKernel32,'GetLongPathNameW');
      // returns length (including #0) of LongPath (or 0 if not found or error)
    BufferSize := GetLongPathName(PChar(FileName),        // lpszShortPath
                                  PChar(Result),          // Out lpszLongPath
                                  0) ;                    // cchBuffer
    SetLength(Result,        // ''
              BufferSize) ;
                    BufferSize) ;                          // cchBuffer
    If BufferSize > 0 then
    SetLength(Result,                                      // remove #0
              BufferSize - 1) ;
// 2/19/2009 - END FIXED CODE ADDED
  end
    result:=FileName;
Comment 1 david berneda 2013-11-20 04:20:17 EST
Thanks for reporting.
Can you confirm which IDE is showing the problem? (Delphi 2009 or 2010?)
Comment 2 david berneda 2013-11-29 10:07:19 EST
Fixes have been applied, but to be compatible with non-unicode Delphi versions, this line should be:
@GetLongPathName:=GetProcAddress(TeeKernel32,{$IFDEF UNICODE}'GetLongPathNameW'{$ELSE}'GetLongPathNameA'{$ENDIF});
