Bug 1136 - an error when adding a Polar Counter series to a project
Summary: an error when adding a Polar Counter series to a project
Version: 150120
: Normal minor
Reported: 2015-02-12 20:55 EST by Shinobu Nagai
Modified: 2015-06-02 21:20 EDT (History)
2015-05-13 22:59 EDT, Shinobu Nagai
PolarContourSeriesFormatLevelTab (21.28 KB, image/png)
2015-06-02 21:19 EDT, Shinobu Nagai
Description Shinobu Nagai 2015-02-12 20:55:57 EST
There is no special step to reproduce this problem. If adding a Polar Counter series and finishing a project without saving it, an error occurs.
Comment 1 sandra pazos 2015-02-17 08:09:48 EST
Hello Nagai,
The problem you are experiencing isn't reproducible for us using latest version of TeeChart Pro VCL/FMX build number 2015.14.150120.
Thanks in advance,
regards.
Comment 2 Shinobu Nagai 2015-02-17 21:58:42 EST
Hello Sandra,
This must be occured in a Japanese OS as well as ID:637.
Please check it with a Japanese machine.
Thank you in advance for your help.
Kindest Regards,
Shinobu Nagai
Comment 3 sandra pazos 2015-02-18 08:28:00 EST
Hello Nagai,
Finally, we have reproduced the problem you’re experiencing when we close the IDE without save the project changes in a Japanese O.S.
Meantime, I would like suggest you close the project through File Menu ->Close all or File Menu>Close to prevent the possible problems.
Thanks in advance,
Regards.
Comment 4 david berneda 2015-05-13 09:39:41 EDT
Which error it is? AV ?
Does it happen with all ide's?
"Polar Counter", is it a TPolarSeries ?
Does the error happen switching to form text mode (Alt + F12) and back again to design (Alt + F12 again) ?
Comment 5 Shinobu Nagai 2015-05-13 22:59:20 EDT
Created attachment 442 [details]
Comment 6 Shinobu Nagai 2015-05-13 23:02:56 EDT
Even if we close the project through File Menu ->Close all, it still occurs.
As for the error, please see ID 673.
We confirmed it occured with Delphi2010 and Delphi XE2, but didn't test with all ides.
As for the Polar Countour series, please see the attached PolarContourSeries.png.
The error occurs even if switching to form text mode (Alt + F12) and back again to design (Alt + F12 again).
Thank you in advance,
Comment 7 sandra pazos 2015-06-02 07:39:50 EDT
Hello Nagai,
I have been reviewing the bug and the problem isn't produced for me using Rad Studio XE2 in a JP Windows 7 machine and latest TeeChart Pro VCL/FMX, we published on April 2015, build number 2015.15.150420. Could you confirm if it works in your end?
Thanks in advance
Comment 8 Shinobu Nagai 2015-06-02 21:19:07 EDT
Hello Sandra,
We tested it with the latest version you suggested.
The error didn't occur by adding a Polar Counter series and finishing a project without saving it.
However, if we add one more step to it, ann error occurs.
To reproduce it, please follow the steps below:
1. Adds a Polar Contour series.
2. Opens Chart Editor and goes to the Series tab.
3. Finishes the project without saving it.
Is it related to the Series tab?
As another issue, if we open Chart Editor, goes to the Series -> Format -> Level tabs, some of the strings aren't displayed in Japanese (see PolarContourSeriesFormatLevelTab.png).
Thanks in advance,
Kindest Regards,
Comment 9 Shinobu Nagai 2015-06-02 21:19:42 EDT
Created attachment 457 [details]
Comment 10 Shinobu Nagai 2015-06-02 21:20:57 EDT
Hello again,
I forgot to mention that the Japanese strings are already added to the TeeJapanese.pas file, but they aren't displayed in Japanese.
Thanks in advance,
Kindest Regards,
