Bug 113 - Stack overflow occurs when adding double array
Summary: Stack overflow occurs when adding double array
Reported: 2013-11-19 04:50 EST by refro2
Modified: 2013-11-26 11:04 EST (History)
Description refro2 2013-11-19 04:50:27 EST
When adding two arrays of double values in a chart a stack overflow occurs. The issue was checked against the sources of TeeChartJavaAndroid_3.2012.1120 and it makes sense this occurs.
The offending code:
double[] xVals = { 1, 2, 3, 4, 5, 6, 7, 8, 9, 10};
double[] yVals = { 1, 2, 3, 2, 1, 2, 3, 2, 1, 2};
FastLine line = new FastLine(_chart.getChart());
line.add(xVals,yVals, false);
A part of the stack trace:
E/AndroidRuntime(  520): FATAL EXCEPTION: main
E/AndroidRuntime(  520): java.lang.StackOverflowError
E/AndroidRuntime(  520): 	at com.steema.teechart.styles.BaseLine.add(FastLine.java:675)
E/AndroidRuntime(  520): 	at com.steema.teechart.styles.Series.add(Series.java:3104)
W/ActivityManager(  349):   Force finishing activity com.fancom.android.lumina/.MainActivity
Comment 1 narcís calvet 2013-11-19 05:08:37 EST
This also happens with Swing components. Line series has the same problem but Bar works fine.
