Bug 1129 - Multiline at horiziontal axis
Summary: Multiline at horiziontal axis
Version: 140220
Reported: 2015-02-10 10:32 EST by ronald.eichhorn
Modified: 2015-03-02 04:58 EST (History)
Description ronald.eichhorn 2015-02-10 10:32:16 EST
The Label Position starts outside the Chart if Multiline is selected and two lines should be displayed. Also the margin between tick and Label increases. If multiline is selected and only one line is displayed, everything is ok.
Comment 1 sandra pazos 2015-02-12 10:45:42 EST
Hello Ronald,
Unfortunately, we can't reproduce the problem you're experiencing using latest TeeChart Pro VCL/FMX, build number 2015.14.150120. I would like suggest you download it and try again if the problem persists for you. Here's the download link:
http://www.steema.com/download/vcl
If the problem you're experiencing still appears for you using latest TeeChart Pro VCL/FMX version, we would be very grateful if you can attach a simple code, because we can reproduce the problem here.
Thanks in advance,
Regards.
