Bug 1123 - When cloning a chart series with a datasource, the datasource is unlinked
Summary: When cloning a chart series with a datasource, the datasource is unlinked
Reported: 2015-02-06 04:00 EST by h.hasenack
Modified: 2015-02-12 11:42 EST (History)
Delphi / C++ Builder RAD IDE Version: RAD XE7
Description h.hasenack 2015-02-06 04:00:54 EST
this shows up eg when using the chartscrollpager with a series that is linked to a chartdatasource,
It clones the original series for display in the scrollpager, but when doing so it does not clone the datasource component. So, whap happens ist that the datasource gets linked to the seires in the scrollpager, and the original series gets unlinked from the datasource.
My patch was to change the TChartSeries.Assign method, and skip any TSeriesSource links from the original series in SelfSetDataSources:
  Procedure SelfSetDataSources(const Value:TDataSourcesList);
  var t : Integer;
    {$ifdef HH_PATCH_TC_DATASOURCEPERSISTANCE}
      ds:TComponent;
    {$endif}
    DataSources.Clear;
    // fixes a problem for Tchartscrollpager where a series iscloned. The TChartSeries.Assign
    // unlinks from the original chartseries top be linked to the cloned series. Which makes the
    // original series appear empty.
      for t:=0 to Value.Count-1 do
        ds:=Value[t];
        if not (ds is TTeeSeriesSource) then
          InternalAddDataSource(ds);
    {$else}
          InternalAddDataSource(Value[t]);
    {$endif}
