Bug 1098 - Legends with many items not behaving correctly when being resized or when horizontally aligned
Summary: Legends with many items not behaving correctly when being resized or when hor...
: --- critical
Reported: 2015-01-22 07:30 EST by Shantanu
Modified: 2015-01-26 08:57 EST (History)
Sample example for Legend invisible Items (39.57 KB, application/x-zip-compressed)
2015-01-22 07:30 EST, Shantanu
Description Shantanu 2015-01-22 07:30:30 EST
Created attachment 390 [details]
If legend has many items, then the invisible items are not updating text when window resized or Legend aligned horizontally (top/bottom).
Can you look into this?
More Info:
What TeeChart version are you using?
-- TeeChart for .NET 2012 (4.1.2012.09280)
What IDE are you using?
-- Visual Studio 2013
What language are you programming with?
-- C#
What exact OS are you running?
-- Windows 7 (32 bit)
Shantanu
Comment 1 christopher ireland 2015-01-26 08:57:59 EST
This is an issue with the changing of the Legend text by the cursor tool. The correct way of doing this is as follows:
      tChart1.Resize += tChart1_Resize;
    private double xval;
    private void ChangeLegendText(double xValue)
      if (!_isLoaded)
        return;
      xval = xValue;
      for (int i = 0; i < tChart1.Series.Count; i++)
        if (tChart1.Series[i].Active)
          if (tChart1.Series[i] is Steema.TeeChart.Styles.Custom)
            string legendText = tChart1.Series[i].Title + ": " + InterpolateLineSeries(tChart1.Series[i] as Steema.TeeChart.Styles.Custom, xval).ToString("0.00");
            tChart1.Legend.Items[i].Text = legendText;
    void tChart1_Resize(object sender, EventArgs e)
      ChangeLegendText(xval);
    private void cursorTool1_Change(object sender, Steema.TeeChart.Tools.CursorChangeEventArgs e)
      ChangeLegendText(e.XValue);
