Bug 1096 - Polar draws a point at coordinates origin
Summary: Polar draws a point at coordinates origin
Version: 140923
: High normal
Reported: 2015-01-22 05:26 EST by narcís calvet
Modified: 2015-03-25 09:51 EDT (History)
Chart Series: Polar
Description narcís calvet 2015-01-22 05:26:58 EST
This can be reproduced with this code:
uses TeePolar;
var
  Series1 : TPolarSeries;
  i : Integer;
  Series1:=TPolarSeries.Create(Self);
  Series1.Pointer.Visible:=False;
  Series1.Brush.Style:=bsClear;
  for i:=0 to 359 do
    Series1.AddPolar(i+10, 0);
  Chart1.Axes.Left.SetMinMax(-1, 1);
  Chart1.Axes.Bottom.SetMinMax(-1, 1);
  Chart1.View3D:=False;
  Chart1.AddSeries(Series1);
It works fine with TeeChart.NET:
      Steema.TeeChart.Styles.Polar polar1 = new Steema.TeeChart.Styles.Polar(tChart1.Chart);
      polar1.Pointer.Visible = false;
      polar1.Brush.Visible = false;
      polar1.Pen.Color = Color.Red;
      polar1.Pen.Width = 3;
      for (int i = 0; i < 360; i++)
        polar1.Add(i + 10, 0);
      tChart1.Axes.Left.SetMinMax(-1, 1);
      tChart1.Axes.Bottom.SetMinMax(-1, 1);
Comment 1 narcís calvet 2015-03-25 07:53:12 EDT
The problem is the code snippet below at the end of TCustomPolarSeries.InternalDrawValue in TeePolar.pas.
      if FirstValueIndex<>LastValueIndex then
        OldX:=CalcXPos(0);
        OldY:=CalcYPos(0);
        if (OldX<>CircleXCenter) or (OldY<>CircleYCenter) then
          MoveTo3D(CircleXCenter,CircleYCenter,StartZ);
          LineTo3D(OldX,OldY,StartZ);
Comment 2 narcís calvet 2015-03-25 08:27:18 EDT
There's also a problem with the line below at TCustomPolarSeries.InternalDrawValue in TeePolar.pas.
      LineTo3D(CircleXCenter,CircleYCenter,StartZ);
Which should be
      LineTo3D(X,Y,StartZ);
