Bug 1094 - version info for trial version
Summary: version info for trial version
Reported: 2015-01-22 00:57 EST by Shinobu Nagai
Modified: 2015-02-25 23:34 EST (History)
Caption of Version info for Eval version (60.48 KB, image/png)
2015-01-22 00:57 EST, Shinobu Nagai
Revised About box (67.48 KB, image/png)
2015-02-24 06:28 EST, christopher ireland
Description Shinobu Nagai 2015-01-22 00:57:52 EST
Created attachment 388 [details]
Please see the attached image. Version dialog for the trial version is obsolute. Could you update it?
Comment 1 christopher ireland 2015-02-23 11:48:39 EST
Would you be so kind as to specify the content you want to see in this dialogue?
Comment 2 Shinobu Nagai 2015-02-23 19:09:51 EST
I'm afraid v4.1.2014.12155 shouldn't be TeeChart Pro .Net v2010.
Comment 3 Shinobu Nagai 2015-02-23 20:00:19 EST
Could you be so kind to change it to "TeeChart Pro .NET JP について"?
Comment 4 christopher ireland 2015-02-24 06:28:39 EST
Created attachment 404 [details]
Revised About box
Attachment showing the revised about box.
Comment 5 Shinobu Nagai 2015-02-24 19:43:19 EST
Hello Chris,
Thank you for the fix. This is trivial, but it will be nice if the caption would be left aligned, instead of centered.
Also, we noticed the version number is obsolute. Isn't it a problem?
Comment 6 christopher ireland 2015-02-25 04:31:25 EST
The caption is actually the Form's Text property:
https://msdn.microsoft.com/en-us/library/ms159419(v=vs.80).aspx
I can see no other Form property which gets or sets the alignment of this Text.
The version number would be an issue if the image of the About box was generated by a publicly available release version of TeeChart.dll. This is not the case, however.
Comment 7 Shinobu Nagai 2015-02-25 23:34:24 EST
In Revised About box, I see there is blank spaces before "TeeChart Pro .NET JP について". We wanted to remove the spaces, but if it's not possible, then could you please replace it to "About TeeChart Pro .NET JP"?
