Bug 1076 - Not able to plot X and Y Axis Line Graph according to dates
Summary: Not able to plot X and Y Axis Line Graph according to dates
Version: TeeChart for .NET 4.1.2013.11080
Reported: 2015-01-07 06:39 EST by devisree.korlakunta
Modified: 2015-01-12 08:28 EST (History)
Chart Series: Line
Sample date time and values and acutual graph and trying to plot graph. (45.60 KB, application/x-zip-compressed)
2015-01-07 06:39 EST, devisree.korlakunta
Description devisree.korlakunta 2015-01-07 06:39:50 EST
Created attachment 379 [details]
Iam Plotting a Line graph in wpf in which horizontal axis is date time and vertical axis is value.
  GraphChart.Aspect.View3D = false;
            Steema.TeeChart.WPF.Styles.Line obj2 = new Steema.TeeChart.WPF.Styles.Line(GraphChart.Chart);
            obj2.VertAxis = VerticalAxis.Left;
            obj2.XValues.DateTime = true;
            obj2.Stairs = true;
            obj2.UseAxis = true;
            obj2.Visible = true;
            obj2.Color = Colors.Red;
            obj2.ShowInLegend = false;
            obj2.Chart.Axes.Bottom.Automatic = false;
  GraphChart.Series.Add(obj2);
  for (int i = 0; i < SensorList.Count; i++)
                GraphChart.Series[0].Add(listplotsensor[i].SensorDate, listplotsensor[i].SensorValue);
SensorList is a list contains no of sensors(ex it has 1088 points) and Listplotsensor has list of datetime and values.
In the attachment I have attached Dateandvalues.png values which are sample values to plot
Acutal graph.png is the graph which it should look like
graph.png is the graph iam trying to plot. in Graph.png the bottom axis should be in dated and the dates gap should be one day.
example from 1st date to 2nd date it has 15 points to plot.
Its a urgent requirement. Please do the needful.
Comment 1 sandra pazos 2015-01-12 08:28:41 EST
What you request are not bug fix or enhancement suggestion to the existing products but technical inquiries on how to use TeeChart. Please post this kind of questions at our technical support forums, monitored by our technical department staff, at http://www.teechart.net/support/index.php
Anyway, if you want achieve that request you can try to do something as I do in code below that works fine for us using latest TeeChart.Net release build number 4.1.2014.12154
    {      GraphChart.Aspect.View3D = false;
            obj2.Stairs = true;
            GraphChart.Legend.Visible = false;
           DateTime dt = new DateTime(2000,12,10,10,0,0);
         for (int i = 0; i <50; i++)
           if (i!=3)
             GraphChart.Series[0].Add(dt, 0.1);
             GraphChart.Series[0].Add(dt, -0.2);
           dt = dt.AddHours(1);
         GraphChart.Axes.Left.SetMinMax(-1, 1.5);
         GraphChart.Axes.Bottom.Labels.DateTimeFormat = "MMM dd, yyyy HH:mm";
         GraphChart.Axes.Bottom.Increment = Steema.TeeChart.WPF.Utils.GetDateTimeStep(Steema.TeeChart.WPF.DateTimeSteps.OneHour);
         GraphChart.Axes.Bottom.Labels.Angle = 270;
Thanks in advance,
Regards.
