Bug 1062 - Incorrect series marks text alignment for TPointSeries
Summary: Incorrect series marks text alignment for TPointSeries
Version: 140923
Reported: 2014-12-24 07:29 EST by sandra pazos
Modified: 2014-12-24 07:29 EST (History)
Description sandra pazos 2014-12-24 07:29:16 EST
When you use marks with a specific angle on top of the point value of series point and these are transparent (no box, no border). The marks overs the point a bit and it isn't aligned on top of the point value.  The problem isn't occurs in TeeChart Pro VCL/FMX Build 2012.07.121105
The code below reproduces the problem:
uses Series;
var  Series1 : TPointSeries;
procedure TForm2.FormCreate(Sender: TObject);
var i:Integer;
Series1 := TPointSeries.Create(Chart1);
Chart1.AddSeries(Series1);
Series1.Stairs := False;
Series1.Marks.Angle := 45;
Series1.Marks.Visible := true;
Series1.Marks.Transparent := True;
Series1.Marks.TextAlign := taLeftJustify;
Series1.Marks.Font.Size := 8;
Series1.Marks.Style := smsLabel;
Series1.Marks.Visible := True;
Series1.XValues.DateTime := True;
for i:=0 to 20 do
Series1.AddXY(i,5,'Label:'+IntToStr(i)+'01234');
