Bug 1061 - Can't load themes in Client Profile
Summary: Can't load themes in Client Profile
Component: Importing (show other bugs)
: Low enhancement
Reported: 2014-12-24 05:39 EST by yeray alonso
Modified: 2015-01-16 07:13 EST (History)
Description yeray alonso 2014-12-24 05:39:18 EST
This works fine with the regular TeeChart.dll but fails with the Client Profile dll:
  Chart1 = new TChart();
  this.Controls.Add(Chart1);
  Chart1.Dock = DockStyle.Fill;
  Area area = new Area();
  area.FillSampleValues();
  Chart1.Series.Add(area);
  Steema.TeeChart.Themes.ClassicTheme chartTheme2 = new Steema.TeeChart.Themes.ClassicTheme(Chart1.Chart);
  try
    chartTheme2.Apply(Chart1.Chart);
  catch (Exception ex)
    Console.WriteLine(ex.Message);
First, the ClassicTheme.ten isn't found (it has to be added to the ClientProfile project TeeChart.Client40, and probably the other .ten files too).
Then, I still get a SerializationException:
System.Runtime.Serialization.SerializationException was unhandled
  HResult=-2146233076
  Message=No se puede encontrar el ensamblado 'TeeChart, Version=4.1.2013.5281, Culture=neutral, PublicKeyToken=9c8126276c77bdb7'.
  Source=mscorlib
  StackTrace:
       en System.Runtime.Serialization.Formatters.Binary.BinaryAssemblyInfo.GetAssembly()
       en System.Runtime.Serialization.Formatters.Binary.ObjectReader.GetType(BinaryAssemblyInfo assemblyInfo, String name)
       en System.Runtime.Serialization.Formatters.Binary.ObjectMap..ctor(String objectName, String[] memberNames, BinaryTypeEnum[] binaryTypeEnumA, Object[] typeInformationA, Int32[] memberAssemIds, ObjectReader objectReader, Int32 objectId, BinaryAssemblyInfo assemblyInfo, SizedArray assemIdToAssemblyTable)
       en System.Runtime.Serialization.Formatters.Binary.__BinaryParser.ReadObjectWithMapTyped(BinaryObjectWithMapTyped record)
       en System.Runtime.Serialization.Formatters.Binary.__BinaryParser.ReadObjectWithMapTyped(BinaryHeaderEnum binaryHeaderEnum)
       en System.Runtime.Serialization.Formatters.Binary.__BinaryParser.Run()
       en System.Runtime.Serialization.Formatters.Binary.ObjectReader.Deserialize(HeaderHandler handler, __BinaryParser serParser, Boolean fCheck, Boolean isCrossAppDomain, IMethodCallMessage methodCallMessage)
       en System.Runtime.Serialization.Formatters.Binary.BinaryFormatter.Deserialize(Stream serializationStream, HeaderHandler handler, Boolean fCheck, Boolean isCrossAppDomain, IMethodCallMessage methodCallMessage)
       en System.Runtime.Serialization.Formatters.Binary.BinaryFormatter.Deserialize(Stream serializationStream)
       en Steema.TeeChart.Import.TemplateImport.Load(Stream stream) en C:\root\TeeChartforNET\Version 4\Sources\TeeChart\Export\Exports.cs:línea 7322
       en Steema.TeeChart.Themes.Theme.ApplyFromResource(Chart Dest, String ResourceName) en C:\root\TeeChartforNET\Version 4\Sources\TeeChart\Theme.cs:línea 733
       en Steema.TeeChart.Themes.ClassicTheme.Apply() en C:\root\TeeChartforNET\Version 4\Sources\TeeChart\Themes\ClassicTheme.cs:línea 73
       en Steema.TeeChart.Themes.TeeChartTheme.Apply(Chart AChart) en C:\root\TeeChartforNET\Version 4\Sources\TeeChart\Themes\TeeChartTheme.cs:línea 75
       en WindowsFormsApplication1.Form1.InitializeChart() en C:\Users\norike\documents\visual studio 2010\Projects\WindowsFormsApplication1\WindowsFormsApplication1\Form1.cs:línea 38
       en WindowsFormsApplication1.Form1..ctor() en C:\Users\norike\documents\visual studio 2010\Projects\WindowsFormsApplication1\WindowsFormsApplication1\Form1.cs:línea 20
       en WindowsFormsApplication1.Program.Main() en C:\Users\norike\documents\visual studio 2010\Projects\WindowsFormsApplication1\WindowsFormsApplication1\Program.cs:línea 18
       en System.AppDomain._nExecuteAssembly(RuntimeAssembly assembly, String[] args)
       en System.AppDomain.ExecuteAssembly(String assemblyFile, Evidence assemblySecurity, String[] args)
       en Microsoft.VisualStudio.HostingProcess.HostProc.RunUsersAssembly()
       en System.Threading.ThreadHelper.ThreadStart_Context(Object state)
       en System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
       en System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
       en System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
       en System.Threading.ThreadHelper.ThreadStart()
  InnerException:
