Bug 1034 - Cannot Compile Standard version with SourceCode in XE5
Summary: Cannot Compile Standard version with SourceCode in XE5
Version: 140923
: High blocker
Reported: 2014-12-09 14:03 EST by Bruder
Modified: 2014-12-22 09:28 EST (History)
Description Bruder 2014-12-09 14:03:47 EST
Procedure TTeeCanvas.TextOut(const X,Y:{$IFDEF FMX}Single{$ELSE}Integer{$ENDIF}; const Text:String; AllowHtml:Boolean);
  if AllowHtml then
     HtmlTextOut(Self,{$IFDEF FMX}Round{$ENDIF}(X),{$IFDEF FMX}Round{$ENDIF}(Y),Text)
     TextOut(X,Y,Text);
Compiler Error
Inkompatible Typen: VCL.Tee.TeCanvas und TeCanvas.TTeeCanvas
in Line HTMLTextOut....
Comment 1 sandra pazos 2014-12-11 06:37:37 EST
The problem you are experiencing doesn't appear for us when we create a simple TeeChart Winform application with latest TeeChart Standard VCL/FMX source code in RAD Studio XE5 Update 2.
Maybe the problem can be caused because is necessary to have installed the XE5 update 2. Please, check if you have installed the update. If the XE5 update 2 isn’t installed in your IDE, please install it. Here’s the update 2 download link: http://cc.embarcadero.com/item/29708 . If you have installed update 2 and the problems persist, please attach for us a simple project so we can try to reproduce the problem here.
Thanks in advance,
