Bug 1031 - PolarChart: Inconsistent data display on ClockWiseLabels
Summary: PolarChart: Inconsistent data display on ClockWiseLabels
: Normal minor
Reported: 2014-12-04 06:42 EST by narcís calvet
Modified: 2014-12-10 11:08 EST (History)
Chart Series: Polar
Example showing the two cases described above. (42.71 KB, application/x-zip-compressed)
2014-12-04 06:42 EST, narcís calvet
Description narcís calvet 2014-12-04 06:42:08 EST
Created attachment 359 [details]
The label direction on Polar series can be set by the ClockWiseLabels property. I found the following behaviour in TeeChart 4.1.2014.8123:
When I set the direction and then add data, the data is drawn at the wrong polar angles.
When I add data and then set the direction, the data is drawn as expected.
Example:
The following code draws data at the wrong positions. E.g. the value "2" is drawn at 270° instead of 90°.
        private void btnDirectionBeforeData_Click(object sender, EventArgs e)
            Polar newSeries = new Polar();
            newSeries.CircleLabels = true;
            newSeries.Color = Color.Red;
            newSeries.ClockWiseLabels = true;
            newSeries.Add(0, 10);
            newSeries.Add(90, 2);
            newSeries.Add(180, 4);
            newSeries.Add(270, 8);
            tChart1.Series.Add(newSeries);
The following code draws data at the correct positions.
        private void btnDataBeforeDirection_Click(object sender, EventArgs e)
            newSeries.Color = Color.DarkGreen;
I have attached a sample which demonstrates the behaviour.
Comment 1 narcís calvet 2014-12-10 03:58:43 EST
Looking at ClockWiseLabels implementation this can be readily understood:
    public bool ClockWiseLabels
      get { return clockWiseLabels; }
      set
        if (clockWiseLabels != value)
          clockWiseLabels = value;
          ModifyData();
          Invalidate();
    private void ModifyData()
      for (int i = 0; i < XValues.Count; i++)
        XValues[i] = 360 - XValues[i];
Which is to say that if there is no data in the series, there are no XValues and so no data will be modified. Data has to be first added to the series before it can be modified to make the labels "clockwise".
