Bug 1030 - The legend checkboxes are positioned incorrectly when legend alignment, is top or bottom
Summary: The legend checkboxes are positioned incorrectly when legend alignment, is to...
Version: 150120
Reported: 2014-12-04 05:31 EST by sandra pazos
Modified: 2015-04-16 07:30 EDT (History)
4 users (show)
LegendCheckBoxes (37.06 KB, image/png)
2014-12-04 05:31 EST, sandra pazos
test project (2.08 KB, application/zip)
2015-04-16 05:15 EDT, yeray alonso
The test project works not for me. (155.68 KB, image/jpeg)
2015-04-16 05:29 EDT, Bert Kreisel
Description sandra pazos 2014-12-04 05:31:30 EST
Created attachment 358 [details]
LegendCheckBoxes
The legend checkboxes are positioned incorrectly when legend alignment, is top or bottom. The attached image illustrates the problem. Also, the code below reproduces exactly the problem.
uses Series,Chart;
var Chart1 :TChart;
 Chart1 := TChart.Create(Self);
  Chart1.Parent := Self;
  Chart1.Align := alClient;
  Chart1.View3D := False;
  Chart1.Legend.Alignment := laTop;
  // Create Series
  Chart1.AddSeries(TFastLineSeries.Create(Self));
  Chart1[0].FillSampleValues();
  Chart1[1].FillSampleValues();
  Chart1[2].FillSampleValues();
  Chart1.Legend.CheckBoxes := True;
Comment 1 yeray alonso 2015-01-27 07:20:56 EST
This was broken in Chart.pas rev 1.93 when improving the Dividing Lines.
Now fixed.
Comment 2 yeray alonso 2015-02-09 08:42:24 EST
Found the proposed fix still fails in some circumstances.
http://www.teechart.net/support/viewtopic.php?f=3&t=15397
Needs a revision.
Comment 3 yeray alonso 2015-04-16 05:15:25 EDT
Created attachment 426 [details]
test project
Attached project to test different situations for the legend.
Comment 4 yeray alonso 2015-04-16 05:16:33 EDT
The test project seems to work fine for all the possibilities.
Comment 5 Bert Kreisel 2015-04-16 05:29:02 EDT
Created attachment 427 [details]
CheckBoxes are only in first column of legend with Position Bottom or Top.
Comment 6 yeray alonso 2015-04-16 07:30:41 EDT
I've just sent you the modified units in the internal sources.
These changes will be applied in the next maintenance release.
