Bug 1028 - TFastLineSeries don't draw some points in different X position when DrawAllPointsStyle is daMinMax
Summary: TFastLineSeries don't draw some points in different X position when DrawAllPo...
Version: 140923
Reported: 2014-12-01 08:53 EST by yeray alonso
Modified: 2015-01-29 03:54 EST (History)
Chart Series: FastLine
Description yeray alonso 2014-12-01 08:53:53 EST
In the following example, the chart is shown correctly until you zoom it clicking the button. At that moment, the point (25000, 1) isn't drawn any more.
uses Series;
var i: Integer;
  Chart1.Legend.Visible:=false;
  with Chart1.AddSeries(TFastLineSeries) as TFastLineSeries do
    for i:=0 to 50000 do
      case i of
        25000: Add(1);
        25002: Add(-1);
        else Add(0);
    DrawAllPoints:=false;
    DrawAllPointsStyle:=daMinMax;
  Chart1.Axes.Bottom.SetMinMax(24950, 25050);
  Chart1.Axes.Bottom.Automatic:=true;
Comment 1 narcís calvet 2015-01-26 07:35:56 EST
This works fine with TeeChart.NET:
      InitializeChart();
      Steema.TeeChart.Styles.FastLine fastline1 = new Steema.TeeChart.Styles.FastLine(tChart1.Chart);
      for (int i = 0; i < 50000; i++)
        switch (i)
          case 25000:
            fastline1.Add(1);
            break;
          case 25002:
            fastline1.Add(-1);
            break;
          default:
            fastline1.Add(0);
            break;
      fastline1.DrawAllPoints = false;
      fastline1.DrawAllPointsStyle = Steema.TeeChart.Styles.DrawAllPointsStyle.MinMax;
      tChart1.Axes.Bottom.SetMinMax(24950, 25050);
      tChart1.Axes.Bottom.Automatic = true;
