Bug 1024 - Update.exe tool changes the offset values of bottom axis in design-time mode
Summary: Update.exe tool changes the offset values of bottom axis in design-time mode
Reported: 2014-11-27 06:39 EST by sandra pazos
Modified: 2014-11-27 19:34 EST (History)
Versions images (118.67 KB, application/x-zip-compressed)
2014-11-27 06:39 EST, sandra pazos
Description sandra pazos 2014-11-27 06:39:46 EST
Created attachment 353 [details]
Versions images
Basically, the problem causes an increment the offset values of bottom axis when you update the project from v8 to v2014.0.0.2. The attached image shows the exactly problem. It only occurs if you add a Series in Deisgn-Time mode. To reproduce it you only must do next:
1. Registers TeeChart8.ocx and creates a new project in VB6.0.
2. Places a TChart control, adds a BarSeries from Chart Editor and saved the project.
3.- Update the project from v8 to v2014 with Update utility.
4- Open the project again. The problem appears.
