Bug 1015 - Removing Panel Gradient and Back Wall Gradient at design time doesn't take effect
Summary: Removing Panel Gradient and Back Wall Gradient at design time doesn't take ef...
Reported: 2014-11-17 06:00 EST by yeray alonso
Modified: 2016-04-20 08:19 EDT (History)
Description yeray alonso 2014-11-17 06:00:59 EST
If you open the editor at design time and you disable the gradients at Chart/Panel/Gradient or at Chart/Walls/Back/Pattern/Gradient you can see the changes at design time but these are lost when you run the application.
After stopping the the execution, back at design time, the gradients are active again.
Workaround: do it at runtime:
TChart1.Panel.Gradient.Visible = False
TChart1.Walls.Back.Gradient.Visible = False
Looks similar to this:
http://bugs.teechart.net/show_bug.cgi?id=777
It works fine in TeeChart VCL.
Comment 1 pep jorge 2016-04-20 08:19:48 EDT
Fixed for the next v2016.0.0.0
