Bug 100 - Methods RemoveAt and Remove, don't remove the markers of NumericGauges
Summary: Methods RemoveAt and Remove, don't remove the markers of NumericGauges
Reported: 2013-11-14 04:53 EST by sandra pazos
Modified: 2013-11-14 07:42 EST (History)
Description sandra pazos 2013-11-14 04:53:02 EST
When you use the methods RemoveAt or Series.Remove to clear Numeric Gauges, the Gauge is removed but its markers not. The method works in correct way for the other series.  See next code to reproduce the problem:
          Steema.TeeChart.Styles.NumericGauge num = new Steema.TeeChart.Styles.NumericGauge();
          tChart1.Series.Add(num);
            tChart1.Series.RemoveAt(0); //tChart.Series.Remove();
            tChart1.Refresh();
Comment 1 christopher ireland 2013-11-14 07:42:30 EST
This is not a bug. The reason is that neither Remove nor RemoveAt are designed to Dispose of the series. You can see this in the comment of the SeriesCollection.RemoveAllSeries, which says, "Removes all Series from the Chart but not disposes (destroys) them".
You will note that calling Dispose on the series works as expected:
    Steema.TeeChart.Styles.NumericGauge num;
      num.FillSampleValues();
      num.Dispose();
